Hi,
I am having a fuel problem with my 1993 Ciera 2655 5.0L LX. It starts right up and runs perfectly for about 7 or 8 min and then starts to miss and drop in rpm until I eventually have to shut it down. I thought it may be water in the filter so I took the filter off and drained it. The engine starts right up and works perfectly for another 7 or 8 min and then starts to miss again. I noticed that as I slackened the filter I heard a suction sound. After noticing that I then only had to slacken the filter and not drain it. Once I tightened the filter back up the ran perfectly for a while and then repeat problem. I am wondering if this is vapor lock or is the fuel tank vent plugged or blocked off. Tomorrow I will run it with the fuel filler stopper off and see what happens. Anyone else have this problem. Any suggestions?? Thanks.
