Got out today for the first time this year and had a problem. First off its an 85 bayliner capri with aq125a/270. Started great and ran great. 15 mins out the temp started to rise over 180 at 4000rpms so I backed the throttle down a bit. Still rising slowly so I shut it down to take a look. All looked fine. Poped the coolant cap off slowly and it was empty. Where could it have gone? I let it cool down and filled with water to get me back. When I got back it was hot and empty again. It's not leaking out anywhere but has to be going some where. Where should I start? Thanks for any and all your help!
overheated and coolant gone????????-gctid384492
Yes its over full. I had milky water about a month back. Drained and refilled. Checked compression it was 140 to 160. So thought maybe it was either submerged at some point before I got it or condensation. Now that I got the boat running it seems its still a problem. So coolant must be geting into the oil. Where do I go from here?
Ok. I just figured the good compression test would rule out the head or head gasket being the problem. Guess I'm wrong. Thanks for your reply. And I guess I will tear this thing apart.
I wouldn't play around with it too much. I just had the same issue with my daughters vehicle. After doing a compression test which was "fine" she drove it the next day and blew the motor.
Sounds like the heads to me but hope for just head gaskets.
Good Luck!
