2655 Listing to port-gctid384017
    Hello
    Can anyone help? My 1996 2966 Bayliner is slightly listing to port. It was not doing this last year, it came out of the water over the winter and suffered some water ingress which has filtered through into the back cabin. The hood is being replaced, I'm concerned there could have been some osmosis on the port side which is causing it to list. I've tried tried different amounts of fuel and water to counter balance with no effect. There is no water in the bilges, the boat has been dried out internally yet the boat continues to list a few degrees to port when just sitting in the water. Is there anything else I need to do to counter balance this, or what might be causing it?
    Slatters wrote:
    Hello
    That would be a huge amount of water one one side to get the boat to list... seems unlikely to me. Are you sure you didn't put in/take out any heavy equipment (i.e. downrigger balls, generators, tool boxes, etc.)?
      Hi Slatters,
      I could not find any comments on your topic, hope you solved your problem since this is quite a while ago.
      I have Just bought a Bayliner ciera sunbridge 2655 from 1991 and I am having the same problem on the starboard side.
      I am reading a lot on this forum about lists to either side and about weight transfer but I don't thing that that is the problem with my boat.
      Did you find out what the problem was with your boat?
      Thanks a lot in advance,
      Rens
      Holland
        "Slatters" post=384017 wrote:
        Hello
        On my 2655 my two batteries were on the port side as well 6 gallon water heater.
          2012 maybe the boat sank ...
            I wouldn't answer any ad for a boat that said "Just listed.".
            1996 2252 LS Capri Cuddy Cabin. Merc. 5.7L . Port Perry, Ontario, Canada.
