Hi All-
I seem to be having an issue with the air con in our 305. I am somewhat used to marine air. We had it in our 2004 265 and now in our 305. Typically, if we set the air at too low of a temperature relative to conditions, it seems to freeze up, as indicated by a decreased air flow from the vents and the air that does come out is not as cold. I am used this and considered it to be normal. We would just set the temp high enough so that the unit could achieve the temperature and kick off. Although this did not get it as cold as I would sometimes like, it would allow it to keep running properly. This was the same on our 265 and 305.
My concern now is that the air does not seem to run as long before it stops being effective, or "freezes up" as I would call it. This weekend, the water was around 55-60 degrees, the air temp was in the low 80's. We would set the air to 71 degrees, and it would seem to only run for about 20-30 minutes properly before the airflow would slow down and the cabin temp would rise. Ultimately, the cabin temp would creep up to 73 degrees, and we would shut the unit off for about twenty minutes, let it "thaw" and then restart it again where it would work well for another twenty minutes or so.
Any thoughts on this? Any similar experiences? Thanks!
