Hi, I've been a looker forever and took the plunge on a very clean 1986 2550 with the AQ260 and a VP280 drive on it. By everything I can see and tell the drive train is stock.
Without going into the engines internals are there some basic suggestions concerning alterations to improve my fuel economy. The boat is a life long pacific Coastal toy. has new bottom paint and matching new drive. n motor has less than 100 hrs on the top end about 800 hrs on the bottom end but opened up and inspected, always very well maintained. i'm an airplane mechanic and chevy based hotrods but your insight would be great. I'm fine with the performance levels and use a floscan and all it does is scare my check book.
Prop suggestions?
Distributer ? type or timing suggestions?
carb? 4 barrell dialed in vs same cfm 2 barrell, Vac. or mechanical on the 4 barrell?
Any thing?
Thanks in advance, happy camper regardless,
Rory
Prop suggestions?
Any thing?
Rory
