What is the diffrences between a 1989 2455 and a 1988 2655. I am trying to figure out if some of the interior parts and canvas can be swapped out or not. Guess what I am asking where did they stretch the extra 2 feet?
What is the diffrence between 2455 and 2655-gctid378283
Some of the interior parts might swap depending on what it is you want to do.
Matt Train
BOC Site Team
Chicagoland, IL
They are 1 foot apart in width and 2 feet in length.
I used to have a 2455 (which it seems you have), now I have a 2655. The inside is totally different and the canvas will not fit without major work.
google a 89 2655 that is for sale and look at the interior pics. I can't see anything that could be swapped.....
The top definitely will not work. The 2655 is both wider and longer. I could see where seating MIGHT work, but now you'd have to find an expert on both the 2455 and 2655 which might be challenging. I can tell you that on the more modern ones (98-05 range) the seating is also stretched in length. Even the flip bolster on the port seat/lounge is wider on those. So I really doubt anything will fit.
The seating up top will not work either. The 2455 has a straight L and the 2655 has more of a U shaped seat. The rear seat is also bigger on the 2655. Maybe the drivers seat....Thats about it imo.
Kind of figured as much. Saw a set of interior v berth/dinning room cushions and canvas top for sale on craigs list for a 1988 2655 for $400. I wondered if the interior would be usable since it was described as resently being redone. I kind of figured the canvas would have been pretty much usless but figured I could resell and get most of my money back or talk they guy into selling just the interior cushions. Oh well I will just have to live with my own work that still works but of a grey instead of tan color so it does not match the old stuff as well
