MidGrade still the why to go with a 350 mag engine?
Gas Octane-gctid377949
If the engine does not knock or ping, and is tuned properly you should not need anything but reg. gas, but if you are a go as fast as you can, it would not hurt to use mid grade if it makes you feel more secure. Considering the price of gasoline, the difference in cost is not much.
Happy boating, in 30 days so will I be on the water.
