I own a 2006 Bayliner 305 and am looking to upgrade my anchor to stainless.What is the best kind and size for my boat?
Best kind of anchor is best-gctid376110
Anchors type depends largely on the bottom found when you anchor.
We are also in Lake St Clair and have had great success with a 33 lb Rocna. I have 30 ft of 5/16" chain and 300 ft of 5/8" three strand nylon.
We had a 22 lb Delta and at times it seemed insufficient.
Jim McNeely
Twin 5.7s with Bravo2 drives
Brighton, Michigan USA
MMSI # 367393410
I do not know your waters, but I favor the claw/bruce type anchor, 22 lb should work for you, if you have a windlass then mabe a 33 lb, a number of BOC members like the claw anchor also, 25 to 30 ft of chain should be good unless you expect heavy winds, what can help on a blow is a weight or a 10-12 lb folding anchor or even a weight with 6 ft of SS cable and a very heavy duty SS snap link you can send down the line, it helps with any surge, mine is 12 lb for my 3870, set up to stop at the top of the chain.
I also have a 16 lb folding anchor with another 40' of 1/4" chain and 300 ft of 5/8 rode for a spare.
I would never expect to use my second anchor since I anchor in well protected coves out of Seward, AK, but I have it, ebay has saved me a lot of money by waiting all winter for that good deal.
A safe anchor and anchorage gives a lot of peace of mind, especially for the wife and kids.
I do not know your waters, but I favor the claw/bruce type anchor, 22 lb should work for you, if you have a windlass then a 33 lb would be a good choice, I know nothing about the Ronca anchor, research it. A number of BOC members like the claw anchor also, 25 to 30 ft of chain should be good unless you expect heavy winds, what can help on a blow is a weight or a 10-12 lb folding anchor or even a weight with 6 ft of SS cable and a very heavy duty SS snap link you can send down the line, it helps with any surge, mine is 12 lb for my 3870, set up to stop at the top of the chain.
We switched to a delta last year and I am very happy with the results.
Jim, those are GREAT prices on a stainless anchor. Vicky would shoot me if I got one.
1998 3055 Ciera
(yes, a 1998)
Previous boat: 1993 3055
Sea Doo XP
Sea Doo GTI SE
I just upgraded a few weeks ago. I switched from a 14# Delta to the Rocna 15 (33 lbs). Haven't tried it yet but i have never heard anyone say anything bad about the Rocna. Of course, if you want the stainless steel version, be prepared to shell out the BIG bucks. I bought the much more reasonable-priced galvanized version.
2003 Bayliner 305 - SOLD!
Twin 5.7L, Carb'd, 445 hours
Bravo II drives
Closed-cooling
The anchor should be chosen for the type of bottom you will use it in. Also remember that having plenty of chain is more valuable than a bigger anchor; it really helps. You should have a foot of chain for every foot of boat length.
I have had a 25 pound CQR and 30' of chain for about five years now, and absolutely love it. Never slips, and we often have to anchor in 70' of water with less than 3:1 scope.
I use a 15 kg Bruce and carry a Danforth (can't remember the size). So far we have always used the Bruce with 70 feet of chain and up to 100 feet of line but we mostly anchor in less than 20 feet of water (8-10 if I can find it). I think the chain is the secret as long as you use one of the mainline anchors.
I have a diver friend that swears that hinged plows (CQR) never dig in and mostly just lay on their side and drag but I have no experience with them. The 44 foot trawler I was on had a CQR but we anchored with all chain and it was never windy.
My Bruce held through one big storm in a sheltered anchorage.
Im considering an upgrade to a stainless 14 or 22 lbs for my 2012 255 as the stock anchor is grossly under weight. Will this style of anchor work with the stock bow anchor roller that comes on the Bayliner or do I need to change it out?
Thx
Fred
2012 255 SD
Venice, FL
"Relax Inn"
2012; 255 SB Bayliner
Venice, Fl
prior boat:
2011; 180 BR
