seal rub rail with 5200?-gctid373698
    Im loosing the sealant mainly above the rub rail on my 2655 it is basically rolling of with minor effort , seems to be a white silicone . I doubt going back with a white silicone is the thing to do, but i do have a tube of 5200. Can i use this after i prep the joint or is this overkill ? what is correct product to use? will the 5200 yellow? im in Chicago do wwe dont get the intense equator sun here. Id like to get this project done today but if i need to order a different material ill have to wait.
    Don't use 5200. It's way too aggressive. Use 4000UV. It will allow you to take the components apart if need be. 5200 won't.
      thanks todd , im searching it now.
