I was wondering if anyone knew of a company near Harrison twp,Michigan (lake st Clair) who makes custom dashes. Not looking for anything crazy just want to duplicate my burl wood gauge cluster. Mine is cracked and I know there are people out there who do it but I am not looking to take my dash apart for weeks while I wait for a new one in the mail. Thanks
Who does custom dash panels-gctid373487
SomeSailor makes nice ones.
Or you can get it from the manufacturer. What do you have?
Jim McNeely
Twin 5.7s with Bravo2 drives
Brighton, Michigan USA
MMSI # 367393410
I have a 2006 305. The corners on both panels have a crack from the screw being tightened to muchI heard somesailor does them but was hoping to find someone local. Buying them from the manufacture will cost twice as much. Any help is appreciated.
Which panel do you need ?
I have had panels made by MMES Custom Panels you can see some of them at my link below. None of my panels were the actual dash panels. He made my Battery, Breaker, and ACR control panels and several placards.
He did make me backlit switch panels with replaceable backlit labels. I need to post photos of these.
The fellows name is Mark. He will do business with you even if you mention my name.
I know he made a full set of Burl 305 dash panels for BOC member Brutus. Brutus added panels you won't see on other 305s. Brutus added a lot of things you won't find on other 305s.
Jim McNeely
MMSI # 367393410
I would check with a local sign shop. They are often equipped to make small plastic signs and may be able to do a dash-size piece as well. I have used a place called "Signs by Tomorrow" but there are other chains as well.
P.s.
i need the dash for my instrument cluster and the large "blank" dash below that. Neither of the panels are bad other than the fact the the corner is cracked but unfortunately my OCD won't allow me to not replace them
Shoot me an email at [email protected]
Don't dally... it's a crazy busy time of year (and I have my own boating to do...)
Hi somesailor,
I have sent you a couple emails but didn't hear back, I must have a bad email for you. I just sent one to your gmail account.
