I would like to run some aux lighting on the boat like red white and blue twinkle lights attached to the railings(holiday stuff). I would like to do this while underway. Is it going to be ok to run the gen set tied into the shore power and run the engine at the same time? I dont want to take a chance on messing up the charger or refrigerator or any of the other electrical stuff. The gen set is a Honda 2000ie which sets on the swim platform.
Running the Gen set while underway?-gctid372295
One thing to pay attention to. Don't have the on board battery charger switched on while the genny AND the engine(s) running.
I did just that on my 38- ran all the Christmas lights on the genny while in the Christmas parade. No problems at all.
I run my built-in generator while under way all the time. I've wondered if the water movement can reduce the water flow into the generator, but have never seen anything to suggest it's a problem. Anyone have an opinion on that?
These work while under way, its what my a/c system has and it works fine while moving. Others have had loss of water when moving with other designs.
Many boats use their generators while under way. I think any build in genny would work that way.
Why not an inverter to run lights while underway?
Doug
When you get into the bigger boats, many of them run their gensets 100% of the time they are away from a dock. Owners arrive at the boat, start the genny, sometimes more than 1 genny, disconnect shorepower and leave. The genny runs 24/7 until they return to the dock.
I will do this on occasion, like when I'm transiting some St. Lawrence Seaway locks. My fridge, freezer and icemaker are all 110VAC. They will run off the inverter but if I'm idling a lot or travelling slowly I will run the genny.
biohazard wrote:
It depends on the through hull you have. I know some a/c through hulls do not work underway.
Doug
2850Bounty wrote:
The OP is asking about the Honda 2000 ie.
My thoughts exactly. Use LED lights, and operate them from your inverter.
biohazard wrote:
I was refering to carlos or anything else using a built in gen.
In which case I agree that the thru hull would be scooping forward in order to run while under way at above hull speed.
2850Bounty wrote:
Ah, I stand corrected! :surr
I was hoping you would bold half my words and give me 10 pics, I am disapointed! :surr
I saved a whole trip when my Alternator took a dump ,, fired up the Honda and it took over all the charging chores
2651 got fun? wrote:
sticking with the OP's question and not the other BS that is ever present on here anymore ..
