Hi folks. So I am just about to buy a 1987 Honda 9.9 4 stroke. Appears to run well, good shape with low hours. Long Shaft (measures 23.5" from underside of bracket to top of the cavitation plate). I have had a bracket fabricated. The set up I am attempting to copy is the Ron Steele version - one of the threads in the archives. My questions and concerns are 'shaft length'. I have attaced several photos to hopefully make my point. It seems from reading most posts, the closer to centerline, the better. I must go to port, but even if I go max port, I still won't get all of the prop below the hull, which, if I understand from most folks, is ideal. And I know the further port I go, the more list I'll get, plus this diminishes comfort/ease of use while trolling, as I will be using an extended tiller handle for control. I'd appreciate any advice/input. Thanks
Attached files [img]/media/kunena/attachments/vb/642932=23188-Honda Outboard.jpg[/img] [img]/media/kunena/attachments/vb/642932=23186-Kicker Bracket 1a.jpg[/img] [img]/media/kunena/attachments/vb/642932=23187-Kicker Bracket 2a.jpg[/img]
