rectangle sink-gctid371775
    I need to replace a deep rectangle in my bayliner 3058 motor yacht. I cant find one anywhere. HELP
    I had a specialized one made for me a few years back.. its a "chaffing pan" for a cook table.(like the pans in the subway sandwich table). they drilled a hole in one area for the drain and up along the rim for the faucets.. it was the perfect size I needed and didnt look hooky.. the sinks on the boats are made from the same materials, so why not try this.. you can pick up them at any restaurant supply store.. they come in a bazillion sizes and styles.. add a bead of silicone to the rims when mounting and poof.. cheap fix and no one will know.. I have picks on my other puter, or I would post it for you..
    there also is a dude on Ebay who makes them too and sells them.. mine was a triple one they did for me.. welding them together and beaded silicone down the edges
    by doing it yourself, you will save hundreds..
    here is a pic link to one like mine I had made.. you can get the jist if it by the pic..
    http://www.ebay.com/itm/JUST-MFG-TRI...item3f1604b8bf
      Thank you so much for the info.
