Did mine this weekend. Washed it down with 3m boat wash then I use meguires cleaner wax. I did the top side yesterday took about four hours. Today the fishing buds who are a few years younger than I am did the hull from the rub rail down. Took two of them about 3 hours, all by hand. I do it twice a year. We will take it fishing for the month of May and then do it again the first part of June as part of the clean up after fishing. After that I use the wash and wax soap during the season. I did the 3m oxidation restorer a few years ago and now I find this routine works well. I will admit I am very, very sore and there will be some Advil in my future.
Things I(39)ve learned from buffing boats-gctid371220
Guest repliedI usually spend 8-10 hrs just buffing out the lower hull on 32-35' boat. Polish and wax is another 6-8 hrs but it does look great and will last for a year....
Guest repliedMidnightSun wrote:
Obviously she finishes before me and helps by waxing the arch and upper area while I continue on the top side.
5hrs??? My boat is 1 1/2 hrs drive from home. Usually go up with my wife and we start prepping. She gets things on board in order and I start buffing the hull. Obviously she finishes before me and helps by waxing the arch and upper area while I continue on the top side. We sleep at a nearby hotel and start again in the morning. Takes about a day and a half although when we splash we are 99% ready for the season.
Guest repliedNehalennia wrote:
Go back and do it again. You went too fast if it only took 5 hours. This time show us some pics :-)
Guest repliedGo back and do it again. You went too fast if it only took 5 hours. This time show us some pics :-)
Guest replied...take two Advil 1 hour BEFORE you start buffing! You will be to sore afterwards to get your hands to your mouth!!!
kwb wrote:
5hrs isn't bad to rub & wax the hull of 30' boat
Mine tends to be an all day event.
carguy wrote:
Annual torture session is done. Buffed the Krab yesterday. The lesson would be never arm wrestle someone who details for a living.
My forearms are so sore, I can't scratch my nose. Boat looks good though. Due to a spring flood forced early launch last year, it had been two years since I did the hull below the rubrail and it took about 5 hours to get it right.
