Could somebody tell me the width and height of the cooler compartment? Would like to know if my Honda EU2000 will fit there?Thanks for any help.
02 2855 Rear Seat Cooler Specs?-gctid370042
joe440 wrote:
I have a 2455 but the cockpit layout looks the same. I can fit an Igloo Marine 48 quart cooler under the seat. It just clears on the height but plenty of room on the width. Hope that helps.
ChillinDaMost wrote:
A Honda EU2000i fits beneath the rear seat on my 2001.
It will not fit in the cooler niche below the lounge seat, but as mentioned will just fit under the rear seat (with less than a quarter inch to spare)
I tried all locations for my Honda 2000 on my '02 Ciera. Yes.... it will also fit in the transom locker, but wouldn't leave room for much else. Also consider this, My transom locker gets kind of wet in a heavy rain (even with the cover up) It is frequently musty and moldy in there, so I'm not sure that's you best spot. I keep mine under the rear seat on an aluminum tray that makes it easy to slide in and out (since we leave the carpet down) Any reason why you don't want to keep it there?
PS.. cooler niche dosen't have enought height
Impulse wrote:
So I just got my 2855 and I am hearing two terms I am not familiar with ... I have a cooler niche? and a transom locker?? Sorry for the ignorance, still learning about my boat.
Seaquel wrote:
Yes, sorry I was replying to the original post regarding the 2002 2855. The 97 as far as I know has neither, at least not the way it is on later models. Your storage is configured differently I believe
