I need to order or source locally one of these brackets to remount my swim ladder Having trouble tracking one down, it would help if I knew what it was called.
What is this bracket called?-gctid369868
Just found it on my US Marine Part List for the 2859, they call it a pivot bracket, part number 2353. Thanks.
The fitting you are looking for is called a GUDGEON. There are a few dealers on the net that supply them, just make sure you order for the proper size tubing you have.
Good luck.
