Sacrificial zincs for diesel engine cooling system-gctid343344
    We have recently purchased an 1989 4588 Bayliner with twin Hino diesel engines - wondering if we should have zincs placed inside the cooling system - any help on this? We have been told by friends that we should have these, but there is no mention in the engine manual. Thanks alot,
    As much as it pains me to write this - I don't think it helps with the common failures with manicoolers.
    The design is a terrible mis-mash of materials begging for problems but as I understand the design the salt water side drains when engine is not running so the time where you have a conductive electrolyte is actually pretty minimal. Based on the teardown of my coolers indications inside confirmed that the seawater does drain almost completly.
    I just did a lot of reading about peoples failures of manicoolers (which I was getting close to a failure myself) and my general opinion is that casting quality is inconsistent - my hunch on this is that the original tool was a multi-cavity arrangement and not all the sections of the mold filled/cooled the same. When you couple hot runners out of the exhaust manifold, a semi-porous casting (or at least less than ideal grain structure), and coolant that does not have inhibitors to prevent microboiling you end up getting pitting that I think often gets attributed to the assortment of dissimilar metals.
    Nobody gets out alive.
      I have looked at my shop manuel and it does not show anywhere that there are factory installed zinks on either the 175hp or the 220hp
      turbo hino engines. Maybe Earl ( MR HINO)will chime in if he knows of anything different. Hope this will help.
      Bob
      Arizona Bob & Sandy
      1990 3888 Bayliner
      Purchased new
      Twin 175 Hino's
      630 Hurth Trans
      Westerbeke Generator
        Correct no zincs in the engine. Some trans coolers may have them depending on po replacement
