Bottom paint done, now electrolysis absorbing items??-gctid368757
  • Bottom paint done, now electrolysis absorbing items??-gctid368757
    Well my first time of sanding and putting bottom paint on is completed and made the boat look like new. Wow what a difference!
    Now a friendly boating neighbor noticed something as he was congratulating me on the btm paint. Something about replacing the "?!&" on the lower unit That it absorbs the electrolysis that is in the water that either my boat gives off or others around do.
    Anyone know what these were called or anything about them?
    Thanks in advance
    Thanks in advance
    Probably talking about your sacrificial anodes. Perhaps they need to be replaced.
    Rick Grew
    2022 Stingray 182 SC
    2004 Past Commodore
      Yes I believe that sounds familiar to what he said. Thanks
        BoatZincs.com is a great site for anodes. They have some good reference charts.
        There are several kinds here are general guidelines.
        Zinc - Salt Water
        Aluminum - Brackish water
        Magnesium - Fresh Water
        Your outdrive will have several anodes. One on each trim cylinder and one or more on the drive itself.
        Likely another on the hull and one on each trim tab if you have them.
        By the way do not paint the drives with bottom paint.
        Leave about an 1-1/2" unpainted strip around the outdrive. This is to protect the aluminum drive from the copper in the bottom paint. See the photo below.
        Jim McNeely
        Twin 5.7s with Bravo2 drives
        Brighton, Michigan USA
        MMSI # 367393410
          hmmm im in fresh water and i think i have zinc on mine. your saying i need mag? add that to the list for this year i guess...lol
            I am in about as fresh as fresh water gets. No need to go the pricy Magnesium route whatsoever. Have been using aluminum forever and so has everyone I know. In fact you would be hard pressed to find Mag anodes in all our local marine supply stores. If you do have zinc now, better switch them out though.
            Cheers, Hans
            2007 Carver 41 CMY
            Twin Volvo D6-370
            Montreal, Canada
            Midnight Sun I Photos
              Just an FYI, note that Rick refered to these as sacrificial anodes, of which is correct.
              You'll often hear "zincs" being used as a generic term. They are only "Zincs" when the material is zinc.
              Just a little pet peeve of mine!
              Wayne, notice Jim's bottom paint and how it's held back from the out drives by 1" or 1-1/2" or so.
              Make sure that you the did same if it's conductive bottom paint.
              Volvo Penta Duo Prop Drives
                and the purpose of these is exactly what? And what happens if mine are gone and havent been replaced?
                  Crud. Umm nope. I didn't hold back on the bottom paint near the out drives. I cut it in like a painter pro. What is the purpose of holding back ?
                    Most bottom paint has metals in them.
                    I believe you are taking any electrical current in the water and connecting it to just the place you don't want it. You may also be getting static electricity from moving through the water. I know there are others that know more about this.
                      Sacrificial in that they corrode instead of the drive corroding. With them gone, your several thousand $$ drive will rot out. Not a good thing.
                      Cheers, Hans
                      2007 Carver 41 CMY
                      Twin Volvo D6-370
                      Montreal, Canada
                        As other posters have stated, bottom paints generally contain metallic ingredients.
                        When two different types of metal come into contact e.g. copper in bottom paint and aluminium in your outdrive, whilst immersed in liquid (water), a process known as electrolysis can occur. Electrolysis will consequently cause corrosion of those metals i.e. your outdrive casing and inner parts may corrode.
                        Sacrificial anodes are used so that they can corrode instead. The materials, zinc, magnesium etc from which anodes are made tend to be the most sensitive metals to corrode during electrolysis, which is why they will "sacrifice" themselves before any metals in your outdrive will.
                        I hope this explains it for you.
                        Best to remove your bottom paint around your outdrives.
                          Well, that would have been a good thing to know about before they splashed me... can I replave them after its in the water? I suppose i can research this on my own too, its just so easy to ask you veterans. Thanks much!
                          • #14
                            Yeah Wayne a must... spend the 50 bucks for the kit.. ill help ya put em on.
                            • #15
                              No arguement from me. As I said in my original post BoatZincs.com has great reference charts.
                              My rough guidelines was meant to be an initial offering. I always lean to the safe side offering recommendations.
                              Jim McNeely
                              MMSI # 367393410
