hino parts-gctid368722
  • hino parts-gctid368722
    Hi where can i get parts for my 210 hp turbo hinos in qeensland australia im having real trouble finding any where. I just had two parts made by marine castings but found this site and alot off talk about hinos in the archive i really only need impellers now but will off course need parts in the future any help would be awsome. thanks seth
    North Harbor Diesel in Anacortes WA USA Most of the turbos are IHI mfg and are used on a lot if different products. There are Turbo rebuilders in the Seattle area that can do everything. Unfortunatly that is 1/2 way around the world for you
      Do a search on the internet. When I was looking the rebuild on my WO6TI (310 hp) I found several distributor of parts from "down under" if you need the Manacooler or any advice get in touch with Earl he is the Best.
      I had the 210's in my 3888 and always had good luck with them but as with any Diesel maintenance is key. I would also look at the dampner to make sure it is in good condition. Earl has a place that can rebuild them if need be.
      Post over on the motoryacht section and you may get more info.
        +1
