To get longer time between pumpouts.-gctid571095
    Get a spray bottle of any car wax. Give the toilet bowel a shot once in a while. You don't have to actually wax it but it would be better if you did.
    But just a shot on a dry bowl will make the "stuff" slide down easier requiring less water for a flush.
    Just make sure you don't get the seat too . . . . :P
      I use Pam cooking spray, because I don't know what car wax might do to the bacteria balance in the tank. Pam is just oil, so I think it shouldn't do anything to it.
        I have been doing this for a few years and haven't noticed any difference. I wonder about the bacteria anyway. When you pump a septic tank you have to introduce bacteria to get it started. We pump the tank all the time so I wonder if there is bacteria working anyway.
        I have just been thinking about adding the same stuff you put in a septic tank when I lay it up for the winter. I am in heated storage so it should work on anything left in the tank.
        It used to be you just threw a cake of yeast in the toilet and flush. I don't think you can buy cake yeast any more. I never heard of the dry yeast working but maybe it would.
          I have been doing that since I bought my 87 2455. You are correct it does allow you to use less water to flush and the bowl stays cleaner. I would wax mine in the spring and a couple of times during the season. I would only have to pump out my 3055 once or twice a season since 99% of the time it was only myself on board + I only used the head when I was not able to use other facilities like when I was anchored out.
          Rick Grew
          1981 Carver 3007 Aft Cabin
          2004 Past Commodore
          www.wrycc.com
