Fresh water capacity on 1996 2855-gctid568280
    Can any tell me how big the fresh water tank and waste water tank hold.
    Its been awhile since I had my 1996 2855 but my memory seems to say that both tanks are in the 20+ gallon capacity. I am sure someone else will chime in here with the exact specs.
    Rick Grew
    1981 Carver 3007 Aft Cabin
    2004 Past Commodore
    www.wrycc.com
      Thanks.
        I'm thinking that the holding tank is 20 gallons and the fresh water is 40 gallons.
          Guys you are all awesome as you know I purchased this boat last year never went into the water until two weeks ago so if I sound a little dumb please excuse me one more stupid question do I have to do something to put water in the hot water tank like turn on a valve or something I filled up the fresh water tank is that all I needed to do or is there a valve on the hot water tank that has to be opened again sorry if this is a stupid question don't want to burn the heating element out
            My 99 has 11 waste 30 water
            John McLellan White Rock BC
            "Halifax Jack"
            1999 2855 383 stroker BII
            MMSI 316004337
              There shouldn't be anything special on the hot water tank. Unless it was added by someone. Just turn on the hot water at the faucet and it might bleed out some air if the tank was emptied for winter storage. As soon as it runs a solid stream of water you should be good to go. It will only heat water if the engine is running up to temp or you are plugged into shore power.
              "THE FIX"
              Misc. projects thread
                No.
                Midnight Star
                1996 3587
                Twin diesels, Hino 250's
                Ladysmith, BC
                History: 1996 - 2655, 2001 - 2855, 1984 - 3270
                  . It may only heat with shore power. My 3055 didn't have the engine coolant heat plumbing. Yours might not either.
                  Doug
                  Hanging Loose
                  98 Carver 350 Mariner
                  2013-
                  KRUSTY KRAB
                  2001 305
                  5.7 BII
                  2006-2013
                    Hmmm...mine works both ways. I thought it was standard of boats that had HWT would normally have heat exchanger built into the tank to heat water with engine circulation. Perhaps it was an option. :whistle:
                    "THE FIX"
                      33 gallon fresh water tank, 13 gallon holding tank.
                      If she is raw water cooled most likely not...
                        Of course, raw water cooling never even popped into my head :lol: my bad.
                        "THE FIX"
                          Still early Dave
                            Don't know if this helps, but on my '99 it is 33 gal fresh water, 20 gal black water, per my manual.
