Can anyone give me any info on Volvo AQ151 #250 Engines? Fuel usage @ cruise, RPM Range Etc. would be appreciated. Boat is a 1981 32 foot Explorer twin inboard. Thanks.
Volvo engine info-gctid363743
I can't help you as to what to expect for fuel economy.... much depends on your useage, size of the hull, how you load it, etc.
I will say that these are great little engines and very dependable when kept up on maintenance.
Here's a link to parts schematics for the three versions of the AQ151.
http://www.marinepartseurope.com/en/...t-7744660.aspx
Rick E. Gresham, Oregon
+1 with everyone else. Good motors but in what?
Economy could be 6-7 mpg in a small boat or 1.7mpg as twins in a 28 or 32 footer....
RPM specs with a good tune up and correct props should be WOT at 5000-5500 rpm.
Lots of info in the link below in my sig.
ekuehn wrote:
Roy; I don't have a good answer for your question but I have a question for you. Where are you located (B.C. Canada)? I have a cousin named Roy Kelln. It might be you? Ernie
Roy Kelln wrote:
Maybe. I have relations in the USA. California mainly. I live in Mission B.C. CanadaEven though we are probably not related you must be a good guy because your a boater(most of them are) Sorry for hijacking your thread with all this genealogy crap but the name Kelln is not that common and having the same first name as my cousin, I had to ask. Ernie
1990 2755 Bayliner Merc Cruiser (350 Chev 4 brl) Engine Alpha 1 leg. Merc 9.9 long leg 4 stk Big Ft
No Problem. No, I don't have any extended family in B.C.. My main relations are in Sask. Nice to hear from another vowel less Kelln. Good boating to you.
Roy Kelln.
