Ok i want to talk about the differences between the two because im a little confused about everything, which is the best one to use because i have read that some people say that with the new tanks and the water seperators that ethanol is fine to run in a boat and on the other heard alot of people say NO that this is a big no no. what is acurate here? im totaly confused because i have a plastic tank on my truck and a plastic tank on my bayliner and with the fuel water seperator it seems that it should be fine? im worried about this because i filled my tank at a regular fuel pump that said that it contained less than 10% of ethanol, and if this is bad should i drain the tank and fuel water seperator? i understand the concept of water mixing with fuel is bad but how come it does nothing to my truck is there is similar setups?
