I woke the beast today. Took her top off and started cleaning. Started to wet sand the hull this morning (step 1 of 3) with 600 grit wet sand, then going to do 1000 and lastly 2000. After that do some gelcoat repairs, then buff and wax. This should take the better part of 1 month(weekends) to do.
Bit the bullet today...-gctid361250
Wet sanding is a method of removing shallow scratches, but is mainly used for oxidized/chalky hulls. Scratches or dock rash as I call it, need to be filled and faired.
[img]/media/kunena/attachments/vb/664237=25426-Photo0130.jpg[/img]
http://baylinerownersclub.org/media/...0130.jpg[/img]Thanks kindly for the pic & all.
Sarah
Gary,
I've always used 2000 grit to finish the wet sanding step, then some 3M Finesse-It II Glaze on a buffer with foam pad, and then wax. Lots of work but always gives the gel-coat a nice glossy finish.
