Has anyone had any success towing a jet ski behind their boat? Thinking maybe of attaching it to the swim platform and dragging it along that way. Pro and cons welcome Pics are better.
Towing a Jet Ski-gctid360975
People do that all the time here, read your manual as roger said and enjoy. Its really pretty common here, jetskis burn lots of gas, no need to drive it 40 miles to your destination, smarter to tow it and save the fuel
At present I dont own one so thats why I'm asking about the possibilty of towing. I think a jet ski is a better option then a dingy since we deal with a 5 to 7 knot current on the river. Or is my thinking all wrong here?
for me it makes a geat dingy... the newer internal cooled skis... sea doo.. dont have issues with towing at slow speeds... most of the other models you have to pinch off the water intake line...
There are tow rigs available for purchase, but I have seen some very funtional ones made out of PVC inside a flooty tube. Line through the assembly attached to two points on the back of the boat and one to the front of the jet ski.
I've seen them mounted on the swim platform before, thought about that myself but it'd take some serious restructuring on my 2550....
interesting stuff here...
http://sealiftusa.com/
I just pull mine up onto the platform. Jet-skis are very light so it's easy to do. The Sea Doo isn't as easy.
Here's a pic on a friends behind my 2855
Attached files [img]/media/kunena/attachments/vb/664066=25405-jetski.jpg[/img]
This issue came up a few months ago and I couldn't remember the name of the company I saw in an ad. Towdster.
http://www.towdster.com/
Not the cheapest, but it may give you ideas for a homemade incarnation. Several versions depending on what you're towing and what you're towing with.
Most brands of commercial jet ski's are easily towable, unless it is a 4 stroke Sea-Doo. The hose that is marked with a wrap of red tape needs to be pinched, or even better has a ball valve installed so that it does not get water in the cylinders. You still can tow it, but no speed over 5 mph without the Sea-Doo ($30.00) clamp, or a (Home depot for $12.00) ball valve and 4 clamps.
