We just received our 2022 Element E18 and discovered there are no rod holders. We are not keen on drilling holes into the fiberglass. I was wondering if anyone else has come up with a creative solution to this problem. Any and all help would be appreciated.
Rod holders???
Not to familiar with your boat but I have some that “clamp” on to the rails. They work surprisingly well and can be rotated to fit anywhere without making holes -
Scotty side mount - you're going to want down riggers, rod holder is a part of that.
1985 Bayliner 3270
110 Hino/Hurth 360A
previous = built own Roberts V495, circumnavigated
previous = Apollo 27
previous = Folkes 39, sailed to Hawaii
+ few more before that..👍 1Comment
The base plate is supposed to be bolted onto a vertical wall, then the rest of it is screwed onto that base plate. This does require drilling holes and access from behind to attach large SS washers (or a stainless steel plate) and nuts.
Downriggers keep your fishing lines deep down while the boat is slowly moving. No need for downriggers if you are stationary. My boat came with both "rocket launchers" (tube-type rod holders) and downriggers with rod holders.
There are clamp-on rod holders that you could attach to your engine protector or ski tower. Other than that there is a glue-on mount base from Railblaza (check out their products), or you need to drill holes. If you do drill holes for bolts make sure you have access from behind for large stainless washers or stainless backing plate, or you are drilling into plywood for stainless steel screws. Seal every bolt / screw with something like 3M-4200. It is amazing how water finds its way into screw holes...1989 2159 Trophy Hardtop
5.8L OMC Cobra
2 1/2 year restoration project after "all you need to do is put the rebuilt engine back in".
Mountlake Terrace, WAComment
