1990 2556 Fuel Tank Replacement
    Hello,
    started my fuel tank replacement this weekend. Bought the boat about 2 months ago. Its in overall decent condition, only 600 hours on the 7.4 mercruiser.
    The fuel tank is not leaking but the bildge was a mess so i would like to start off with a fresh bildge, and a fresh fuel tank so i dont need to worry about it.
    Built the gantry saturday morning, and had the motor pulled by 5pm. This was my first engine removal. Had to take off both manifolds and barely squeeze it out.
    Last night i cut out the bulkhead, it was pretty wet. I measured 3" back on the engine stringers and cut them at an angle down. The tank is loose and i can move it, but im going to have to cut stringers further back to get it out.
    Stringers are wet but fairly solid. I was hoping not to have to deal with them.. but fear i may have to. I will see how they are the further back i cut. The engine mount lagbolts were in solid. So hoping it gets dryer the further back i go.
    Thats all for now. And advice is welcome. I will post updates as i go.
    Got the tank out this morning. If anyone is wondering. You have to cut the stringers back 12" from the bulkhead to get the tank out. Also I left the fishwell installed just to see if it could be done, and it can. Barely cleared.
    the area under the tank didnt look as bad as i thought it would.
    Tank is not leaking, for the most part looks really good. But has some pitting at the strap locations. Honestly not as bad as i thought it would be. Now I almost feel like maybe i should get it repaired in lieu of a new one? Possibly fix the pitted areas then paint.
    Any thoughs on this?
    Stringers are solid but moist. Whats the reccomendation? Cut off the top cap of the fiberglass stringers and replace the wood? Or splice back in the 1' i cut out?
      How do you feel about pulling the engines, cutting the bulkhead out, yanking it out then fixing the fiberglass two times? It's out, it's old, you will never have it be this easy to get a new tank in.
      Tally and Vicki
      "Wickus" Meridian 341
      MMSI 338014939
        Nice work dude!
        Agree with Tally. Not sure you’ll find anyone that’ll repair the old tank, I vote go with a new one.
        where you located?
        "THE FIX"
        '93 2556
        Misc. projects thread
          A new tank for speedy tanks shouldnt be more than 2k shipped.
          As for the wet stingers, no time to replace them is better than bow.
          i buy my epoxy and fiberglass from us epoxies. I go cheap on the plywood and go cdx via local builders supply.
          so do it once. Do it right. Power on another 30 plus years.
            Thanks for the advice. Im in Bellingham, so getting a tank from coastline is a pretty easy solution for me. It'll be about $1275 after tax. You guys are right. This is the best time to replace stringer (as ive already cut 1/3 of them out).
            My question is, should i just cut the top of the fiberglass stringer and leave the rest of the sides? Or should i cut the whole stringer shells off? Ive seen people recommend just cutting the top off.
            Builderdude, what type of paint and primer did you use on your tank? I like the look of a white tank.
            Any votes on removing or keeping my fishwell? I like the idea of the shelf over the fuel tank, but feel like more rain water would drip down from the hatch if the fishwell wasnt there.
              Gaskets around the perimeter of the fish and engine hatch’s will keep water from getting in there. You may want to look into modifying the engine bay ventilator grills/collector boxes, OEM ventilators let tons of rain water in.
              I love the non existent fish well on my boat, I open that forward hatch and hop down in there often to check engine oil level, belt tension, timing etc. I also use that space to store two separate shrimp pot lines (400’ each) and marker floats in removable rubber made totes as well as my marine bbq.
              I’d recommend leaving as much of the stringer shells intact as possible and just hog out the rotten stuff, it’ll make glassing things back together substantially quicker.
              On my tank I prepped (sanded and cleaned) and primed with zinc chromate then top coated with rustolium rattle can enamel. If I had to do it again I’d use an epoxy topcoat for even more piece of mind.
              Id also suggest you update and/or replace anything you can get your hands on while your engine is out. I moved a lot of stuff around to improve my engine access as well as increasing bilge pump capacity and adding a secondary bilge pump. Additional batteries sit on custom “shelves” on both sides moving them further away from the engine improving engine access. Your engine bay will be much tighter with ya big block.
              One other thing to consider: concrete removal from the port side box, a simple drill test will reveal if yours has it or not.
              "THE FIX"
              '93 2556
