I recently finished a new watermaker install in our 3988 -- the 100 gallon water capacity is just too limiting, especially with guests that have limited boating experience :-).
I choose to purchase a component system, as it was cheaper, uses standard readily available parts/components, I could install the various components in different places, and I would also know the system better for future maintenance. I really did not have a single place I could completely install a stand alone system. I purchased the system from Seawater Pro ( in Florida). For my system (which produces around 35-38 GPH) -- the total installed cost was around $4300 .. and of course a lot of my time.
I installed the HP and Boost pumps under the aft port cockpit, the pressure vessels on the aft port hull and the control panel and prefilters behind the port cockpit hatch ( for easy access) -- lots of placement planning to make sure I could access the fittings/connections for service and easily change out the consumables ( i.e. the prefilters).
