Cabin LED rope light install 32xx
    Just finished installing LED color changing lighting inside the cabin. I removed the old fluorescent lights.
    I mounted 1/2" aluminum flat stock and used 10mm double sided adhesive. The led lights already come with adhesive tape but I removed it because it is cheap and doesn't stick too well. I used the aluminum to span the gap the fluorescent lights left. Plus the double sided foam tape sticks better to the aluminum than the tiny and other boat materials. The lights are inexpensive, color changing and dimmable.
    James
    Kai Nani, Redondo Beach, CA
    1989 MY 3288
    Hino 150hp with Hurth 630A Trannies
    We also went with RGBW SOFT white LED strips, dimmable, remote controlled...
    loving the indirect subtle lighting .
      Joon,
      did you use a dimmer? Is the color of the led lights similar to the stock rope lights when they are dimmed?
      MV Kia Orana
      Currently Alameda CA
        The dimmer is built into the remote control. Color stays the same as they are dimmed.
        James
        1989 MY 3288
          Yes built in dimmer & soft warm white was important to us.
            That's exactly what I'm looking for to install under-cabinet, and possibly replace the existing rope up-lighting. Where did you order from?
            James
            2000 4788 | "Freedom"
            Gig Harbor, WA
            11' Novurania w/40hp Yamaha
            Cummins 330's and Westerbeke 8kw
            Hull Extension, Chines and Hardtop
              Nice project for next spring...thanks for sharing.
              CapMartin, Montr├®al
              "Belle de Dalhousie"
              1986 3270
              Volvo BB225B
                Amazon prime of course,
                James here's the link...
                https://www.amazon.com/SUPERNIGHT-Wa...46532451&psc=1
                  I used those exact same lights on mine. Only difference was I stuck mine to the backside of the teak trim panel. It’s great running at night with the blue lights, passenger can see and your night vision doesn’t get completely ruined.
                  Esteban
                  Huntington Beach, California
                    Yup or red
                      Do you have them hard wired to a switch, or do you control them with the remote that comes with them? I assume the remote requires line of sight to work. Do the lights have a warm white setting? I can't tell from the product listing, seems that they are only RGB.
                      Did you have any runs that required more than one 16.5' length? I have a few that I'd need to link two strips together and I know a lot of the less expensive lights can't do that.
                      Thanks!
                      James
                      Gig Harbor, WA
                        Yes they are connected to a switch and are also controlled by the remote only to change colors. Yes line of sight. Mine aren’t warm white but I’m sure you can find in that color. And I do have 2 strips connected with no issues.
                        James
                        1989 MY 3288
                          James, RGBWW is what you want!
                          a couple of new links here...
                          https://www.amazon.com/SUPERNIGHT-Fl...l6L&ref=plSrch
                          this is the one I used 3500K...
                          https://www.amazon.com/SUPERNIGHT-Ch...pernight+rgbww
                          Yes it does have a WARM WHITE setting per my admiral's request.
                          Yes I have them wired to a switch... I cut the cord off a DC adapter then hard wired to an existing switched DC circuit, plugged it into a remote IR control module, you're done.
                          I have the very tiny remote IR sensor barely exposed, so it can be remote controlled, dimming feature is just simply awesome.
                          connecting 2 strips is just plug & play.
                            Great info, thanks Joon. To be clear, you only need one "kit" to get the remote and DC adapter, then just connect the additional $12 strings that you need?
                            When connecting to the existing DC switch, you cut the cord on the "light" side of the adapter?
                            From my existing switch, I need to control 4 separate runs of 1-2 strings each (two different up-facing runs, one on each side of the boat, and two different under-cabinet runs, one on each side of the boat...all from the same existing switch). Could this be wired so that the one controller will control all 4 runs? Switch, IR remote, spliced to each of the 4 runs?
                            James
                            Gig Harbor, WA
                              I didn't order a kit, cheap $12 strings still comes with a remote & control module.
                              the DC cord I used was from one of my DC adapter floating around & this plugs into the white control box , 12VDC power supply. So you don't cut anything on the light side.
                              4 separate runs, each individual run is going to require a control box.
                              James, take a look at my video posted above, you'll see the white control box I'm talking about.
