2007 Bayliner 246 Discovery holding tank location and improvements
    Has anyone had success with combatting Head odors by replacing their existing vent line with a larger vent line on a 2007 246?
    Hi Patti, did you ever try this? I also have a 246, and every flush is awful.
      Depending of how much usage the is problems are vent plugged no additive, leakage and with time the hoses will deteriorate and odder will seep out.
        interested in solutions with details
          You may get responses if you start a new thread in the technical discussion forum.
          2013 Boston Whaler 130 SS
