More Winter Work - Wiring
ID:	407952Click image for larger version
Name:	IGN SW Issue.jpg
ID:	407953Click image for larger version
ID:	407954 So knowing that the HALON Bottle in the Engine Room had never been discharged (pic), I wondered why the little green light on the helm never went green (signifying a ready bottle) from date of purchase. Began the process of digging through the wire maze at the fuse panel, and low and behold, trace the wire from the LED down to an inline fuse (checked OK) and then crimped to a 16ga brown with white stripe wire. As there was no voltage at this juncture, and it is supposed to come on with ignition switch, I checked the schematic. Hmmmm -- only wire there labeled BR-W is the Trim Sender wire and is marked NOT USED (no Trim gauge on this boat). I look at the IGN SW, and sure enough - there is a terminal missing a wire (other pic)!!!! Well low and behold, cut the fuse from the BR/W and connect it to the IGN SW and Voila!! IGN on with a green light, just the way the book sez it should be. Now working at identifying all the circuits at that funky fuse block so I'll know where to look in the event anything happens at sea.
    It's all the little things in life and boating.......
    2004 Monterey 282 Cruiser
    Twin Volvo Penta 5.0GXi-E
    SX-M 1.6gr Outdrives
    Docks @ Punta Gorda, Florida
    Good hunting and good job! It is interesting that your ignition worked as it used to be connected. On my boat, we had to cut the electrical wire going to the extinguisher bottle in order to remove the engine to do some work on it When we put everything back together but forgot to connect the wire to the extinguisher I could not get the engine to crank. Connected to wire to the extinguisher and all is well again.
    Enjoy!
    [email protected]
    [email protected]
      Enjoy!
      Thanks. Mine was the low tech model. Acvording to the manual they only run SW power back to the bottle from ignition switch, then to the light then the bottle switch then ground. The theory is that if running and the light goes out the bottle has voided due to fire. As if one wouldn't know that on a smaller boat such as mine (they are pretty noisy when they discharge). Yours was the delux setup and according to the manual the bottle SW can be wired to shut down engine(s).
