32XX Cave steps
    32XX Cave steps
    Not yet finished. I've made the temporary design from plywood, until I'm satisfied. I made it so I can remove the top step hinge pin and fold up the stairs and open the engine access. Any thoughts or ideas to make it better ? The final project will be made from hardwood.
    1992 4588
    WitchWay
    Seadoo Wake 170
    I dispensed with those hinges and replaced them with two heavy hooks. The steps are supported by Al angle underneath. So to access the engine now I just toss them aside. I did however hinge the engine hatchets.
    1987 3270 135-Hino
    Foxtrap, Newfoundland
      Looks nice. I wanted to add an extra step. Each step is now 8-3/4”. It makes going up and down very easy now.
      1992 4588
      WitchWay
      Seadoo Wake 170
        The one piece modification is the way to go. Especially if you'e adding a step. I wish I would have taken the time to do the same. I refinished mine and replaced the original hinges with heavy butt hinges. I welded a little tab on the pin to remove without tools.
        I posted this project but the pics were probably lost in the conversion.
        "Martini's Law" SOLD
        Nova Scotia, Canada
          It's not too late for me to do the one piece/lift away design. I only have to make 1 more wood template. I'm hoping that others will post up photos. So much got lost in the conversion it's hard (impossible) to find photos of past projects.
          1992 4588
          WitchWay
          Seadoo Wake 170
            It' s too bad we lost all those pics. I know others have done the one piece mod. With just the two steps my does pull up fairly easy.
            Nova Scotia, Canada
              Oh, make sure you put a strip of non slip tape or something similar on the finished treads as that polyurethane is super slippery. I learned the hard way.
              Nova Scotia, Canada
                Mine are on my list of spring projects! Looks great! I was thinking of a simple three ladder that hooks on and comes off, so it’s no longer attached to engine access. Keep us posted with the finished product
                Bayliner 3270 1987
                  I have made some progress with the steps. This is the final prototype. I have gone with the one piece design. This is version 2 as the first one was too wide to remove from the lower berth. Now it's narrow enough to remove and put up and out of the way. next job is to sand down and stain.
                  1992 4588
                  WitchWay
                  Seadoo Wake 170
