Bowsprit modification on 2001 3988
    It took long enough but I finally completed the pulpit modification on my 2001 3988; pictures are attached, (only three pictures are allowed per post). The original bowsprit contributed to a LOA of 46' 3". Now, the LOA is about 43' 4". It appears that they used 5200 adhesive under the original pulpit so it took some elbow grease and patience to remove it. Unfortunately, it took some of the gelcoat with it so repairs were needed. Once I removed what was left of the 5200, I used a dremel tool to create a good, clean surface for the Marine Rx. Epoxy. I also used some Penetrating Epoxy on the large hole where the spot light wiring ran through. Once repairs were made, I had a 1/8" thick, polished stainless plate made to cover the area. I also had the stainless guy weld a section of bow rail to close the gap on the front of the boat. In regards to the anchor, I opted for a Bruce type, 44 lb. Lewmar Claw anchor, along with a BRM3 stainless bow roller. Instead of using 5200, with the advice from a buddy, I used copious amounts of 4200 adhesive under the stainless plate and bow roller to provide a water tight seal. If I ever have to remove anything, it will save me a lot of work. Of importance is to make sure you have enough clearance between the anchor claws and the bow of the boat. A dock buddy, with the same boat, made a similar modification but his anchor ended up too close to the bow of the boat. Overall, I'm pretty pleased with the results.
    Alex
    Orange County, Ca.
    2001 3988
    Twin Cummins 330's
    Looks good, nice work.
    Sea Venture
    2000 3055, 5.7/B2, 18x23" props
    Cruising the PNW and beyond.
    DIYC, Riverhouse Marina
    MMSI 316029971
    Kirk
    Drinks well with others.
      Great job Alex!
      Jeff & Tara (And Hobie too)
      Lake Havasu City, AZ
      And 13 others...
        Excellent work buddy!
        Jim Gandee
        1989 3888
        Hino 175's
        Fire Escape
        [email protected]
        Alamitos Bay, SoCal
          That really looks nice!
            OK, now that you have finally got it done and perfected you can start making mine.
            Very nice job.
            1999 Bayliner Ciera 2655
            5.7 Bravo 3
              what you are going to find that is missing is the bail over the roller to keep the line from jumping out on a rough anchorage, or the anchor from bouncing out in a rough seaway... unless you are only a fair weather sailor, it WILL be a problem.
              NU LIBERTE'
              Salem, OR
              5.7 OMC Cobra - 15.5x11 prop
              N2K equipped throughout..
              • Ahaua
                Ahaua commented
                Great observation and I'm already planning on having my stainless guy weld one onto the roller. I'm also looking for either a heavy duty anchor shackle or swivel. The shackle I have on now is only temporary. I'm just having a hard time finding a shackle or swivel that fits both the anchor and the chain. Thanks for your comment!
              Looks great, I’m taking notes.
              "Impasse". 2001 3988
              Cummins 330's
              Puget Sound
              "You don't want to be the richest guy in the nursing home..."
              • Ahaua
                Ahaua commented
                Thanks! I like the saying in your signature....lol....words of wisdom
              Alex,
              you might want to consider bolting on the bale to restrain the anchor rather than welding. That way it can be removed if nessessry. Mine has gotten bent but can be straightened more easily by removing.
              MV Kia Orana
              Currently Enjoying the PNW
              • Ahaua
                Ahaua commented
                Thanks for the advice! Will definitely consider that.....
              I did not install a bail over my BRM3 and that was 8 years ago and have never had an issue with the anchor jumping out nor the line when anchored.
                Ahaua
                Sorry to resurrect an old thread. Have you been happy with this mod over the long haul? Any changes you have or would like to make. Are you happy the the anchor you chose?
                Thanks for any update you can provide.
                Marc
                • Ahaua
                  Ahaua commented
                  Marc, sorry for the late response. I have been extremely happy with this mod! I, honestly, wouldn't change anything. I chose the 44 lb bruce anchor and it worked out great. You may be able to get away with a 33 lb. bruce. Hope this information helps
                I did this mod and have never looked back. Can’t count the number of times I’ve squeezed into a space that having the pulpit would not allow. The shorter LOA will pay for the mod with a hundred more stays at Roche Harbor.
                Only change I made was to install the Wind Line URS-1 roller. It gave me a little more flexibility to adjust the roller forward or aft to fit the anchor, and it fits the Bruce anchor just fine.
                Thanks to you and Guntar for photos and help.
                Cummins 330's
                Puget Sound
                • Ahaua
                  Ahaua commented
                  That looks great and I agree with the advantages of losing the long nose! I also think that the boat looks much better.
                Was the shank of the replacement anchor significantly shorter than that of the original? One of the issues 'm wrestling with is that to do what I would like, I'll need a few inches shorter on the shank. I actually thought about shortening the existing one, but I'm sure someone out there will tell me that messing with anchor geometry is bad juju.
                toni
                Toni Froehling
                Yelm, Washington
                1994 Hino powered 4788
                • Ahaua
                  Ahaua commented
                  In my case, I installed the new roller forward enough to prevent the anchor from hitting the bow and, although the anchor shank is close to the windlass, it worked just fine. I'm sure you've tried making these adjustments and are still having a problem so have you explored other anchor options? I don't know enough to comment on whether it's a good idea to shorten the existing anchor shank. Good luck and let us know what you come up with.
                I and Bal734 have the 44lb bruce and have no issues with clearance or fit? Not sure why you need a shorter shank. You do have to measure exactly the placement of the bow roller. Done properly you should have no issue with clearance.
                Guntar
                1999 3988
                Cummins 270s
                  This is my setup with a 44 lb Lewmar Bruce as well. It fits fine with Bruce and very compact.
                  However, we are not really happy with the Bruce in all situations and are thinking of moving to different and larger anchor such as a Rocna or Vulcan, and to do that we would require a longer Anchor roller
                  The new Mantus bow rollers look great -- more money but very nice products and and have some nice features.
                  Mantus bow roller is an anchor bow roller designed to fit an anchor of any design and when combined with the anchor-mate provides an ultimate solution for anchor storage.
                  Ideally , on the 3988 , the windlass should be moved back as it was placed assuming a long bowsprit.
                  Jim
                  Althea -- 2000 3988 270 Cummins, Hull Extension
                  Semiahmoo, WA
