Flexible Freshwater Tank Installation-gctid828587
    1987 3270 135-Hino
    Foxtrap, Newfoundland
    Colbournee - nice! How did you get the old tank out, cut it up or out whole somehow? How big, gallons, liters is the new tank? Does the new tank empty from front or stern? Any type of guage sender on new tank?
    Thanks Terry
    Terry
    Br$keAweigh
    1987 3270
    H/P - Powell River, B.C.
      wow. nice. that's the cleanest bilge I've seen.
      Novurania 335DL. 30HP. WKRP in cincinnati. Previously: Bayliner 3818 in PNW.
        Diveguy show us how to remove the old tank out the side window! Just search on his post from a couple of years ago. New tank is 200 liters, bit smaller than the Al tank. It emptys from the stern unlike the original. No sender in this thank, that part of the reason why you need quick access just to check things.
        1987 3270 135-Hino
          Nice install colbournee. I've had my bladder for four seasons now and no issues. When you winterize you can direct the water to the pickup corner by lifting the forward section. Once empty I flip over that corner so no water lays in the elbow. I then disconnect the line from the pump and blow in the end to ensure theres no water in the line.
          "Martini's Law"
          Nova Scotia, Canada
            All my pictures are gone!
            1987 3270 135-Hino
              we all must move beyond the point of outrage and fully embrace complacency!
                Thinking of installing a plastimo bladder 52 gallon. Are you still happy with the install? Any pointers?
                1989 Avanti 3450 Sunbridge
                twin 454's
                MV Mar-Y-Sol
                Twin chevy 350's inboard
                Ben- Jamin
                spokane Washington
                  So far so good, see if it survives the winter, I'm sure there is still a bit of water in it. Diveguy has had good success for a few years now I believe. That's the same one we have plastimo 52 gal. The space where the original tank was is a bit larger than what's required for the 52 gal plastimo so I put a bit of framing around it to reduce movement. I also cut out an opening in the bed for the water outlet fitting to drop down into the bed
                  1987 3270 135-Hino
                    I read where when it's full it crowns at the top of the bag. (Which one would expect)
                    how many inches does it crown up do you know? Im putting mine in the cabin floor. i have about 3 inch clearance from the original 50 gallon aluminum tank im just hoping that wil be enough as to not push up on the floor. That wouldnt work if it did.
                    twin 454's
                    MV Mar-Y-Sol
                    Ben- Jamin
                    spokane Washington
                      Great info! I am about to do this to my 3270. Any tips or advice?
