Bayliner 2452 new fuel tank, not cutting deck-gctid826032
    When rebuilding transom, enginestringers and bulkhead I decided to exchange that old aluminiumtank at the same time. I installed 2 pc. 140 liter plasttanks.
    See more in next part
    Sorry for dividing this topic but there are some problems uploading several pics in the same file and also some pics won┬┤t upload at all ;-(
    1995 Bayliner 2452
    Alpha 1 Gen II
    2016 - 5.7 Vortec 4BBL
    Full Closed Cooling
    When rebuilding transom, engine stringers and bulkhead I decided to exchange that old aluminiumtank at the same time. I installed 2 pc. 140 liter plasttanks.
    Also made a removable bulkhead in engine room, pics. in that topic.
    1995 Bayliner 2452
    Alpha 1 Gen II
    Full Closed Cooling
      Fantastic work bent!
      With the new fuel tanks being plastic is there any additional space needed for expansion?
      Is the fuel capacity the same as it was having the original? and I assume you'll draw from one tank at a time.
      I'm sure one of the fellas in software tech can stitch these threads together for you. Keep up the good work!
        One thread Please
        Boatless at this time
          Fuel capacity is decreased by 20 liters.
          Yes I can choose which tank to fill and which to draw from.
          I tried very hard to make one thread but some limits prevent that, sorry
          1995 Bayliner 2452
          Alpha 1 Gen II
          Full Closed Cooling
            Smart .
              Looks amazing. Just curious, but what do you do for a living ?
              Terry
              1982 3270
              Volvo BB 140 A's
              Killbear Marina, Parry Sound, Ontario, Canada
                Thanks Terry
                I'm a service engineer in a Danish company named Roblon and I travel worldwide installing and repairing machines that produces fibre optical cables.
                That's the reason for the sometimes slow progres, right now I'm in Durango, Mexico so no boat work for the next week or more.
                1995 Bayliner 2452
                Alpha 1 Gen II
                Full Closed Cooling
                  Beautifully done.
                  1994 2859 in Tacoma, WA
                  7.4 Mercruiser
                  Still learning about other systems
                  and specs.
                    Nicely done...
                    Doug ;}
                    MMSI: 338068776
                    sigpic
                      The tanks that you used appear to be portable type, is that correct? How are these tanks vented? I ask because portable tanks are not certified for installation in an enclosed compartment and in a compartment connected to the engine.
                      2013 Boston Whaler 130 SS
                      Isla Verde, PR
                        How are you planning to fill the tanks? Do you plan to connect each to a deck plate and run a vent line from each to an exterior vent? I'm also concerned about tank certification if those are designed to be portable. To me it would be like using a metric wrench on an SAE bolt. It might work but may cause an issue. You are doing beautiful work btw.
                        You now have my two cents.
                          These tanks are stationary tanks approved for fixed installation according to the specifications we have in Europe.
                          They are connected to 2 separate deck filler caps and sharing a vent line thats mounted higher than the fuel tank neck so don't worry about the safety, I'm very concerned about the safety for my family and friends.
                          By the way it would be a strange portable tank holding 140 liters of fuel, just joking.
                          1995 Bayliner 2452
                          Alpha 1 Gen II
                          Full Closed Cooling
                            Wow! I used to think my work was cool (you'll remember the thread), but I'm in awe. I've still got to show the completion photos, but my camera messed up. I very seriously considered moving my water and holding tanks to the side like you did, but in the end I didn't. Just awesome work! And a next no-deck-cut fuel tank replacement!
                            1992 Ciera Classic 2452, 5.0 L, 2 bbl, Alpha One Gen II, "Tiwahe"
                            Sittin' in sunshine, Tampa Bay, Florida, USA
                              Great looking work.
