I decided to install a Flowscan and the MPG option (that requires a GPS) wasn't that much more, so even though I didn't have a GPS on the boat I bought the model that supports that. I have several USB GPSs laying around the house and I was hoping I could make them work. I didn't have any luck as USB is significantly different than RS232. I ended up purchasing a GlobalSat BR-355 BR-355 Serial GPS Receiver:
https://www.amazon.com/GlobalSat-BR-...dp/B00AMAJFUO/
for under $30. I used a 7805 regulator I had:
https://www.sparkfun.com/datasheets/...nts/LM7805.pdf
to supply power for the GPS since it needed 5 volts instead of 12. I also attached it to a piece of scrap metal as a heat sink. I was able to take the NMEA + from the GPS and connect it to both the radio NMEA in and the NMEA in on the Flowscan. It was a cheap way to enable GPS without a chartplotter, etc.
