I recently finished upgrading my 1989 Bayliner 2556 from the original chevy 260 HP engine to a 383 stroker with 405 HP and 450 torque. Below are a list of things I also have changed or added:
New engine (Jeggs Marine 383 Stroker)
Removed the shift interrupt (shift assist module)
Removed the 100 lbs of ballast concrete in port side housing.
Moved salon wall 15 inches forward.
Shortened salon bench seating 10 inches.
Built new wall with 5 rack dive tank holder.
Installed sump drain for live well and dive tank well.
Replaced all through hull fittings with stainless steel fittings.
Built a free standing rear cockpit shade.
Added skiff trolling outriggers to side of fly-bridge.
Performance:
Load
5 dive tanks (approx 40 lbs each)
2 adults (340 LBS)
52 gallons of fuel
20 gallons of on board water
40 Lbs of coolers and Ice
Sea state calm with calm winds
As originally purchased OMC 260 Hp
with 15x 14p prop 3800RPM, 15 GPH, 20Kts
with 15 x 16p prop 3600RPM 14 gph 22kts.... difficulty getting on plain and small two foot waves knocked us off plane
Trim tabs needed to get on plain.
With 383 upgrade
15 x14p prop 3600RPM 12GPH 20 Kts
15 x 16p prop 3300 RPM 9-10 Gph 20 Kts 1/2 throttle
15x 17p prop 4300 RPM 18.7 Gph 29.7 Kts 80% throttle
No trim tabs used to get on plane
Performance:
Load
2 adults (340 LBS)
52 gallons of fuel
With 383 upgrade
