Navman Triducer Replacement
Our Navman Triducer Speed/Temp/Depth failed during the 2011 season. A replacement was unavailable as the product is discontinued. I purchased an Airmar P66 style Speed/Temp/Depth Furuno triducer. Airmar is an OEM manufacturer of transducers. An accurate cross reference proved to not be available. After research and examination I was able to determine the wiring color code and cross reference the wiring.
I hope this info helps someone else.
Airmar Transducer |
Navman |
Function |
Color |
Color |
Speed Signal |
Green |
Green |
Speed Voltage Pos |
Red |
Orange |
Speed Ground |
Bare |
Bare |
Temperature |
Brown |
Brown |
Temperature |
White |
White |
Depth Pos |
Blue |
Yellow |
Depth Shield |
Bare |
Coax Shield |
Depth Neg |
Black |
Coax Center |
