Center Console Painting... Not a Bayliner!! OH NO-gctid396940
    Before & After pictures. Just to give an example of what roll on paint looks like on a boat. I basically just took the stickers of, and rolled the paint onto the boat after sanding it. Then I did a wet sand.
    Like I said, not a bayliner, but if you want a before/after picture of rolling/tipping style painting then there you go!
    Fantastic! What kinds of paint did you use? How much was it thinned? What grit sandpaper did you use for final sanding, and wet sanding? How many coats?
