3818 AC Panel Indicator Lights-gctid798787
    Like many of us, most of the AC indicator lights were burned out and better yet, kind of hard to find. I found some LED's on Amazon that would work and bought two packs of ten. The power source green lights were easy, I just had to increase the size of the hole. The fault lights were a bit more challenging. I had seen where some guys had inserted new LEDs through the lenses, but as I began taking one apart I thought about trying to fit the LED's I bought into the old housing and lense. Bingo! Here's the sequence.
    Here's our very familiar reversed polarity indicator
    I first removed the lenses and center divider that slide out
    Then removed the lights and connectors so all I have is the black she'll
    Here's the step drill I used, a #1
    More on the next entry
    1988 3818 "GLAUBEN
    Page two
    I drilled holes in the bottom of the original light housing so that the LED's would snap in
    Once the lights and lenses were in I made up the connections. One wire from the green led to join with the black AC wire, one wire from each LED to join with the white AC wire, and the other wire is from the red light that connects with the green AC wire
    1988 3818 "GLAUBEN
      Page three. Install the new assembly into the original location
      All of the replaced lights working
      Here are the lights I bought
      1988 3818 "GLAUBEN
        Very nice! this will help many members out there.
        Well done Pete :cheer:
        92 2855
        91 Fourwinns 205
          It is nice when the part numbers are included in the post as well, that way we know that they work.
          This is on my to do list too. This will make it easy.
          Thanks Pete!
          Joel
          1987 3818 Hino 175
          "Knotty Girl"
          Prince Rupert B.C.
            Nice work, end result looks great!
            Thanks for the info.
            James
            Hurth 630's Onan 8kw MDKD
            Lowrance Electronics!
            MMSI
            316030379
            VHF CFA2587
            Boating on Georgian Bay
              Very pimpin'!
              Not sure where this falls in my project list, but it is one of the several hundred I have planned. Thanks for the write up and part numbers!
                another project for the list...thanks Pete.
                Dan
                Frostbite Falls, Minnesota
                Claudia V. III
                1988 - 3218
                Gas Drives
                  Don, was that a happy "Thanks" or one of those "thanks a lot" like you didn't need more to your list. :woohoo:
                  1988 3818 "GLAUBEN
                    a happy thanks, I like wrenching on the boat? yacht? tub? or whatever as much as I like going out on it.
                    Dan
                    Claudia V. III
                    1988 - 3218
                    Gas Drives
