The first thing that tipped me off that my drain plug flange was leaking was when I was pulling the boat out of the water a few trips ago, I noticed the entire flange turned 1/8" or so when I cracked the drain plug loose. The leaking flange was confirmed when a few cups of water spilled out of the bilge (not a drop of water entered the boat during the trip). So thanks to a little help from Senior member Rocky_Road, the following project began....Things you will need for the project: 3m 5200 Marine Sealant (i used the 24 hr dry time), Philips head screwdriver, flat head screwdriver, wire brush, couple clean rags
[img]/media/kunena/attachments/vb/696581=28952-1.jpg[/img]First thing I did was put a philips head screwdriver on the screws and made sure the holes were not stripped out. I simply made sure I could tighten all the screws. If yours will not tighten because they are stripped, you will need to drill new holes. Mine were good to go, so I will continue with the project.
[img]/media/kunena/attachments/vb/696581=28953-2.jpg[/img]After removing the flange, I found large amounts of silicone from some cheapy fix someone else had tried at some point in time. I used a flat blade screwdriver (not the best tool for the job, but if you are careful you can use it without scratching the gel coat) to removed the old silicone and get things cleaned up and ready to go.
[img]/media/kunena/attachments/vb/696581=28954-3.jpg[/img]I cleaned up the rest of the surface with a clean wet rag followed by a dry rag. This is the result. At this point you will need to let the transom drain. Water works it way up into the screw holes and back behind the fiberglass. I allowed mine to drain for 5 hours, mixed with a heat gun periodically I got as much drained out as I could. If planned ahead, I would allow a good couple dry days to allow the transom to drain completely. I will probably end up redoing this job at the end of the boating season before winter. But for now, it is much better than it was.
[img]/media/kunena/attachments/vb/696581=28955-4.jpg[/img]This is the back side of the drain plug flange. As you can see it is oily and dirty. I used a wire brush and a wet rag to clean the drain plug flange.
[img]/media/kunena/attachments/vb/696581=28956-5.jpg[/img]Here is the flange all cleaned up. Be careful what you use to clean the flange, the directions on the 3m 5200 sealant are very specific on what you cannot use.
