2556 repower 383 stroker with Bravo 3
    I have just completed a complete repower of my 1990 2556. I replaced the 454 Bravo 2 with a mercruiser 383 mag Seacore, Seacore transom assy and Bravo 3 out drive. Also added Merc Eco gauges.
    Net results were an improvement in every category.
    Planning
    Top speed
    Economy
    This package out performs the 454 in every way.
    I run a heavy loaded boat as well.
    Welcome and thanks for sharing, got any pictures to post of the project?
      Welcome to BOC.
      Glad to hear the results were all positive. I have always thought what you would lose is torque would be made up with the weight reduction.
      1998 3055 Ciera
      (yes, a 1998)
      Previous boat: 1993 3055
      Sea Doo XP
      Sea Doo GTI SE
        Yea, we want pics :P
        "THE FIX"
        Misc. projects thread
          Would like to find out what props your running
            who built the motor, or was it a crate engine or short block?.... I would be interested in seeing the build specs on the engine.
            and im interested in what the boat weighs and what prop you are running as well...
            im in the process of putting a 383 together and hope to see a big improvement as well, but I will be comparing the performance of the 383 against my current 5.7.... which should be a much bigger jump than you seen against your old 454.... ;-)
            NU LIBERTE'
            Salem, OR
            5.7 OMC Cobra - 15.5x11 prop
            N2K equipped throughout..
              It would have been nice to get those details. The thread is about 2 years old and OP's avatar & username suggest he's no longer with us
              "THE FIX"
                I am currently running 3x3 22p props in my 90 2556. Not sure of the weight. Full fuel camping gear 4 people and a dog. I also have a kicker motor and a dingy with a motor. And full fiberglass cockpit cover... so pretty heavy lol. With the current set up I am able to get out of hole without trim and up to a top end of 30k. But I’m only getting 3800 rpm wot. I should be in the 4600 to 5000 range. I have about 10 hrs on the motor and so far... I love the 383.
                  The motor is a merc 383 mag mpi
                    Can you get to the top end of the RPM range at the dock? If yes, you're likely over-propped (or bottom is very dirty causing drag). If you can't get to the max RPM range at the dock, you have some other things going on that require investigation (fuel, injectors dirty etc....).
                    Terry
                    1999 Bayliner 3388
                    Twin Cummins 4BTA
                    Fisherman, Cruiser, Boaticus-enthusiasticus-maximus
                    Member Royal Victoria Yacht Club
                      383 should easily hit 4800 if not 5000. What’s the drive ratio?
                      "THE FIX"
                        I would really like to see all your data before swallowing what you're dishing up here.
                          I ordered Hill marine 4x4 props 18” pitch, so hopefully that will increase my wot rpm to 5000. At the dock I can get 5200. As far as the motor goes it runs great. I replaced the original 454 with the 383 and never repropped so I’m hoping this will fix the issue.
                          Im not sure of the drive ratio. It’s a 97 b3.
                            If you dont get that rpm up, you will quickly damage the engine... because its lugging hard..
                            once you are propped correctly and get the operating range necessary for the engine to work as it should, THEN you can run at any rpm without worry...
                            NU LIBERTE'
                            Salem, OR
