Window leak removal and repair on 246-gctid712094
    Newly acquired 246 had a major window leak on the port side. Removed the window and rebuilt the interior wood casing. Looks great now, no leaks!
    Great job. Did you find where the water was coming in?
      Yes. The screws were stripped out on the window casing. They would not tighten. After I removed the window casing I put some butyl tape to re seal it. Then put a backing plate on the cabin side so the screws can get a bite. It tightened up and made a seal. I had to replace all the rotten wood that was hiding under the vinyl. Now no leaks, thank goodness!
