4788 installation of a vented dryer-gctid704040
    I recently completed an installation of a new vented whirlpool dryer in the bunkroom closet.
    We retained the splendide washer/dryer for the wash function. I am trying to attach photos of the project.
    Great I know that I for one would like to see pictures.
    PuraVidaTN
    2008 490 Pilothouse
    Proud member of the Vol Navy
      I have been singularly unsuccessful in attempting to load the pictures. It appears I have attached the photo files when I send the message, but nothing shows up on the site.
      I will search for a photo attachment training thread. Check back, hopefully I will finally "get it"
        third attempt at adding pictures...
          One more picture.
            I assume that this is a household appliance. Most household AC appliances have the grounding wire (green) and neutral (white) wire connected together. That connection should be separated if the appliance is used on a boat. The ground and neutral should not be connected together on a boat, the exception being when a boat uses an isolation transformer instead of a galvanic isolator. Bayliners typically use a galvanic isolator.
            2013 Boston Whaler 130 SS
              wow. I did not know that. boc rocks!
              Novurania 335DL. 30HP. WKRP in cincinnati. Previously: Bayliner 3818 in PNW.
                Here is some additional information on grounding, neutral and ground, etc:
                http://newboatbuilders.com/pages/ele...y14_print.html
                  Many thanks Norton Rider! Great information.
