I have a 1993 2452 Classic. It has a holding tank. I store the boat on the trailer, and go to and fro on my expeditions using the trailer. I found it was difficult to find a holding tank pumpout at many launch locations, and at home there was no good way to pump out the holding tank. What I really needed was a way to use the trailer dump stations at the state parks and roadside rest areas.
Here is what I did. I stuck a piece of pipe in the outlet of the macerator, one of those white thru hulls. It looked like a 3/4" NPT pipe was a pretty close fit. So I went online and bought a 3/4" NPT tap. It was about $15 including shipping from here: http://drillsandcutters.com/DWTPT3/4...bon_steel.aspx
Using a little WD40 and an adjustable wrench I cut threads into the thru hull. It worked great. I bought a 3/4" male NPT thread/1" push on hose nipple combo from Lowe's in that gray plastic material. 15' of plastic tubing. Now I can pump it out myself. If the cleanout on my sewer were closer to the driveway I could probably do it at home if necessary.
This was a very inexpensive project, and I think worthwhile for those of us trailering boats with holding tanks.
