Redneck Live well 1984 Capri 19.5(39)-gctid681297
    Cheap but works great.
    Plastic storage bin zip tied to swim platform so i can install and remove as needed.
    Transom mounted pump for while sitting still. Plumbing tee trimmed to sit against the bottom to scoop water up into the live well while under way and the pump is out of the water.
    wood strapping to keep the bin form when full of water. Cheap bin is distorted from the weight of water.
    Bungee cords to keep top attached and closed.
    I like it. I made a similar one years ago as well. I had to use the pump for engine cooling to get back to dock when the sea water pump went.
    Joel
    1987 3818 Hino 175
    "Knotty Girl"
    Prince Rupert B.C.
      that is awesome!
