Replaced all the Cabin windows. Had 2 pieces that had cracks, 10 pieces in all.
Here is what I learned.
The glazing tape is amazing, even after 19 years. Removing it is a bear.
To remove all the residual tape, first use a window scraper and change blades often.
Then use acetone and course grit steel wool.
After working a few feet use a clean terry towel to clean up.
Rinse well with soapy water to remove any lingering acetone before applying new tape and windows.
Shoot lines with a pencil so everything lines up.
Double up the tape so the next owner can have just as much fun.
I took the pieces to a local plastics shop. They cut each piece individually use the original as a template and used a router to cut each one identical to the OEM one. And they left the originals attached to the new ones so I could identify them. Not bad for $300.
A friend shot the trim pieces with black paint and clear-coat.
I am very bad at taking photos of work in progress so here are photos of the windows removed prior to cleaning and the finished product. It took years off the boat.
