A little late for a start but none the less it has begun. Definitely too late to turn back.Plan is to split the platform and insert a 20" section in order to make the swim platform more into a lounge area. Reason is I can save the part that attaches to the boat and the rear rounded section where the ladder sits. A rectangular piece in the middle is rather easy to build/instal and minimizes the required finishing. I will need only need to finish the new 20" of side on each side.This will be painted when done however the top portion does not need finishing as I will be sticking down one of these in Faux teak grey colour to go with the black theme on the boat. This type of material is soft on the feet, does not absorb water and no heat retention which is a must. http://www.seadek.com/Here is the platform intact before the split
[img]/media/kunena/attachments/vb/673550=26290-IMG_0281.jpg[/img]Another shot upside down which is already split but pushed together.
[img]/media/kunena/attachments/vb/673550=26291-IMG_0284.jpg[/img]Shown with the 20" gap and actually how wide it will be when done.
[img]/media/kunena/attachments/vb/673550=26292-IMG_0285.jpg[/img]Wish me luck, may need some. :livid:
