I had to restore the photos on this thread, some may be a bit out of order.
So I've decided to dive into my transom repair. After removing just about everything from the engine bay and looping my throttle, shift, steering cables and PA steering cylinder around (with the help of some zip ties), I labeled up the wiring harness, removed it from the transom, and "coiled" it up with the rest of the cables and such.
Then removed my deck drain hoses and scuppers, most of the hardware that holds the swim platform to the transom, and the stainless U bolts. Now ready for some cutting.
You can see at the bottom the glass has delaminated around the drain hole.
Started on the center section first. The glass was only about an 1/8 thick at best till I got down close to the bottom then it got thicker. The plywood (2layers of 3/4 I think) was toast! Half came off w the glass and the rest came off real quick with a flat bar all the way down to the bottom piece around the drain. It was a solid piece of DF and was still sound and seems to be stuck in good but does have moisture in i
You can see the piece of DF right above the flat bar, it has some 3/8 holes in it from the core sampling.
The outer layer of glass measures 1/2 thick around the transom assembly but appears to get thiner as it moves outward, maybe just under 3/8 by the time I got to the part of the transom that starts to angle forward. The core appears to only be 3/8 thick from this point on out to the sides.
Then onto cleaning/removing the last of the engine stringer "pockets
4 separate pieces were used on both port and starboard sides of center section and I could see where the cut lines were previously made.
So now I'm wondering, how do I know if polyester resin was used for the previous repair or epoxy? Is there some way to find out, or should I just grind it all back to where I hopefully will now its original?
EDIT: going back over my thread, I belive this was this was factory work done with polyester resin and the transom is the original BL "quality"
