In need of a place to mount a kicker motor on my transom and at the advice of a few other members (2859'er and SomeSailor) I decided to tackle the task by shortening the port side of the swim platform.
Started with the removal of the old swim step last week. That was more of a challenge then expected with the amount of 5200 used to mount it to the transom. With all supports and bolts removed the 5200 held it firmly in place still. Used a dull wide scraper and hammer in between the step and transom to break through the 5200. After lots of elbow grease success finally came about 30 minutes later.
Had a crazy week at work and the boat is 45 min away, so couldn't do any work during the week. Resumed yesterday. Started by laying out lines for the cuts through the platform and proceeded to cut away. used a circular saw to cut partway through, then finished with a cutting blade on the vibrating tool.
Port Side Before
Port Side After - no turning back now
Port Side Before
